Asus Radeon HD 4890 Voltage Tweak Review
Written by Harry Butler
June 9, 2009 | 10:28
Tags: #hd-4890 #performance #radeon #tested #voltage-tweak
Companies: #asus
Power Consumption (Idle and Gaming)
We tested the power consumption with a Watts Up? Pro power meter, using the device to record the total system power consumption at the wall socket, while we ran three sets of four runs of Crysis in DX10 at 1,920 x 1,200.
Using the data recorded by the meter we could determine the peak output, the consistent minimum and the average load over the entire run of tests.
As both ATI and Nvidia test benches are now identical Core i7 systems, we can accurately determine the apples to apples difference of what power both PCs take to run.
Power Consumption (idle)
Windows Vista Desktop (Aero Enabled)
  • Nvidia GeForce GTX 275 896MB
  • Nvidia GeForce GTX 260-216 896MB
  • Nvidia GeForce GTX 285 1GB
  • ATI Radeon HD 4870 1GB
  • Sapphire Radeon HD 4890 1GB Atomic
  • ATI Radeon HD 4890 1GB
  • Asus Radeon HD 4890 1GB
  • Asus Radeon HD 4890 1GB (Overclocked)
    • 167
    • 190
    • 196
    • 208
    • 215
    • 222
    • 222
    • 233
100
150
200
250
Power at socket (W)
  • Power Consumption (W)
The HD 4890 is an extremely thirsty card and that hasn't changed with the Asus HD4890 Voltage Tweak, with the card slurping up a whopping 222 watts at idle. This rose to 233W when we applied our maximum overclock, making it the most power hungry single GPU graphics card we've ever tested when idle.
Power Consumption (peak)
Crysis DX10 at 1,920 x 1,200 0xAA 16xAF, Peak Power Usage
    • 282
    • 302
    • 317
    • 317
    • 339
    • 363
    • 364
    • 365
200
300
400
Power at socket (W)
The spike in power consumption after overclocking is also very evident at load, with the Asus HD 4890 pulling down a massive 363W at peak when running our Crysis benchmark, roughly the same as Nvidia's GTX 275 and Sapphire similarly pre-overclocked Radeon HD 4890 Atomic.
Posted by Jipa - Tue Jun 09 2009 09:56
MEH. A good overclocker with stock cooling just seems like a bit of a waste. Sure one can swap the cooler himself and sure it helps keep the cost down, but that's just my 2 cents.
It's always nice to see some new features, though.
Posted by Bauul - Tue Jun 09 2009 10:01
I got halfway through the Fallout 3 graphs and gave up. Couldn't there have just been one text line that says "performs same as Reference card"? :)
Fun idea though, hopefully this will pave the way for similar things in the future.
Posted by Baz - Tue Jun 09 2009 10:30
Bauul
It's at the bottom of each results page, and is mentioned a couple of times on the first page - it's a stock card, what do you expect! We wanted to include it in all the results graphs though, as a someone who perhaps didn't know too much about the card could see it's comparison with the competition (I.E.-its the same as any other HD 4890 out of the box)
Still, it's an awesome overclocker, better even than the Sapphire Atomic. Pair with a decent 3rd party cooler and you're in business (although, warranty VOID!)
Posted by Paradigm Shifter - Tue Jun 09 2009 10:31
The boost from upping GPU Vcore is quite impressive. But it badly needs a better cooler. Still for those for whom it isn't an issue (like anyone putting a waterblock on it) then that's a nice boost over stock performance!
null
